carrier bearing misaligned cause vibration? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2004, 01:37 PM
Hello, I am still working on trying to find my vibration on my 86 s-10 2wd long bed..Are there supposed to be shims that go inbetween the carrier bearing and the crossmember to move the bearing up towards the cab. Still havent gone out to measure the drive angles with my angle meter....too cold. I did try and slide the carrier back towards the rear end all the way to see if that made adifference, and nope made it worse if anything
Old 01-10-2004, 02:53 PM
Tazz
vibration?
While you are at it, check for a bent drive shaft.
Tazz
Rat Rods Rule!
