carter 1 barrel - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2008, 09:52 PM
carter 1 barrel
does anybody know what an old carter 1 barrel cfm rating is?
Old 08-20-2008, 01:02 AM
If it is the Carter YF 1 barrel, it should be just under 200CFM if I remember right, I have one on my Gremlin's 232 6 cylinder.
Old 08-20-2008, 07:53 PM
Wiki Edits: 31
if it's the RBS. just over 150 CFM
carter 2 barrel / need info.. hottrodz Engine 0 04-27-2007 07:58 PM
Changing My 1970 Monte Carlo From A 2 Barrel To A 4 Barrel daveh Engine 2 02-20-2007 07:22 AM
4 barrel has less explosive acceleration than my orig. 2 barrel drumharddriveanova Hotrodding Basics 16 11-20-2005 07:42 PM
Can I replace two barrel carb with four barrel on chevy 305 maverick19642001 Engine 6 02-20-2004 10:00 AM
Should I run a 2 barrel intake? CrazyT Engine 2 12-07-2002 11:05 PM
