Carter 4761 To 4758 Swap On a Blower Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2010, 06:15 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
I've got 2 Carter Competition Series 500 CFM 4168's on my blown DeSoto Hemi. They run fine. However, when I start the engine cold, I have to slap the pedal, restart a couple of times, and hold the idle up until it starts to warm up. Neither carb has provisions for a choke. Once the engine is warmed up I don't need to touch the pedal, just turn the key and it starts right up and idles fine. I've scored a 4758 Carter Competition Series manual choke model 500 CFM...same carb as the 4761 only with a choke. Carbs are run Progressive, not straight. My question is could I convert the 4758 to electric choke and replace my Primary 4761 with it (or at least switch tops with the Primary 4761)? Does this sound like it would cure my cold start problem, or would I be sacrificing something or opening up a can of worms?...
Old 11-23-2010, 07:18 AM
345 desoto's Avatar
That SHOULD be "a pair of 4761's" NOT 4168's!...
Cooling system problem after engine swap v8hed Engine 9 10-31-2010 11:14 AM
1989 to 1998 Chevy C1500 Sidestep Engine Swap. 89SideStepMan Engine 8 09-13-2010 06:45 PM
engine swap mvara71 Engine 1 07-19-2010 10:51 AM
53 Packard Clipper Engine Swap? 53packard Engine 16 07-06-2010 04:32 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
