carter 625 on a chevy 305 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2003, 06:15 PM
New Member
Question carter 625 on a chevy 305
i recently put a carter 625 on a my chevy 305 and i has pretty bad throttle response. any suggestions on what i can do to tune up my carb a bit better?
Old 01-16-2003, 07:08 PM
NAIRB's Avatar
Post
what type of intake do you have?
Old 01-16-2003, 08:31 PM
New Member
Post
i have a stock intake manifold with about a 1" spacer in between the manifold and the carb.
the spacer is so i could go from the four big holes on the carb to the two big holes and two small holes on the original stock intake manifold.
Old 01-17-2003, 04:08 AM
Post
I think for a start you should cut out the top of the stock manifold so that it has no holes anymore so it's like two opposing peanut shape thingys divided, hard to explain in words. What happened to your Quadrajet?
Old 01-20-2003, 10:34 PM
New Member
Post
i had the stock rochester on it before and it was goin downhill fast, so i just decided to put a whole new carb on there.
Old 01-21-2003, 07:28 AM
Post
I run a 625 Carter on my 305 and don't have any problems. I run the stock jetting and the accelerater pump in the hole nearest to the carb body. I think you're chasing a timing issue. The 305 likes alot of initial timing. 12* or so. I run the vacuum advance off a manifold sorce, and one light and one medium spring on the mechanical with the stock weights. I use a stock aluminum intake and adapter as well. I tried the Performer intake and didn't like it. Lost a noticable amount of bottom end torque, and gas mileage as well running the same carb. Dan
