carter afb - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2008, 03:24 PM
carter afb
i have a carter afb compitition 4 bbl that i just took apart and rebuilt, I got it all back together but it still dumps fuel after you kill the engine. can anyone help here?
Old 10-29-2008, 04:02 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
maybe;
-float level too high
-float hanging up if the hinge area is bent
-something stuck in the needle & seat like a tiny shard of rubber line
-float has a leak and is partly filled with fuel
Old 10-30-2008, 01:53 AM
JeffB's Avatar
Afb
You need to check your fuel pressure,the AFB's and Edelbrocks work best at 4 1/2 to 5 psi.If it's over that get an inline regulator to bring it down,higher pressures on these carbs will cause the problem you are having, do the pressure check before you check float levels.
Edelbrock VS Carter AFB hollywood2k Engine 22 04-03-2012 05:20 AM
Carter AFB questions. junior stocker Engine 9 05-05-2010 10:33 PM
Carter AFB WOT tuning 70bird Engine 4 08-20-2008 10:28 AM
Carter AFB ScottRods2945 Engine 1 04-22-2007 07:02 PM
Can you ID this Carter AFB for me? unioncreek Engine 2 10-05-2004 01:08 PM
