Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carter AFB 9635SA troubles?
Old 08-23-2012, 10:24 PM
raguza123 raguza123 is offline
I have a Carter AFB 9635SA Carb that has been giving me a headache, it has a rough idle and a miss and pop. It's on a 326 engine it has electric choke and it's opened up, I have cleaned it 3 times, soaking and then blowing out with air. installed 2 kits in it and have checked myself twice before assembling, making sure it's right. Still has a rough idle, I have to back out the mixture screws 3 turns to get it to idle and turn the idle stop screw in 2 full turns so it won't stall. it's sputtering at the exhaust.
I have it at stock configuration which is the same as an Eddy 1406.
What could be ailing this carb?
Is it worth it to try and get it right?
Or move on?
