Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carter AFB 9635SA troubles?
Old 08-24-2012, 12:30 PM
Fang16's Avatar
Fang16 Fang16 is offline
Last journal entry: Project change
Originally Posted by raguza123 View Post
I have a gasket with 4 holes in it for a Carter AFB and a 1/4" 4 hole spacer made for Carter/Edelbrock it's like a heat shield.
So what are you saying I should be using a Q-jet on this intake?
Bump my timing to 12 BTDC, It's a stock 326 with a Comp Cams close to stock?
I asking why I should, will it her anything
Poping out of the carb usually means it's running lean. check for vacum leaks esp around the two base gaskets.
The Following User Says Thank You to Fang16 For This Useful Post:
raguza123 (08-25-2012)
