Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carter AFB 9635SA troubles?
Old 08-24-2012, 05:24 PM
raguza123 raguza123 is offline
you buy them on ebay as a heat shield they are built to the type of carburetor. Carter, Qjet, so on so on
I get one for you
I install a gasket on the manifold then the spacer and a gasket on the top of spacer then carb. all have 4 holes in them.
