Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carter AFB 9635SA troubles?
Old 08-25-2012, 01:50 PM
JeffB's Avatar
JeffB JeffB is online now
Print this and save it: http://www.mymopar.com/downloads/carterafbtuning.pdf one of the first things you might try as you don't need to go into the Carb is changing the pump shot,check out that section first.
The Following User Says Thank You to JeffB For This Useful Post:
raguza123 (08-25-2012)
