Carter AFB 9635SA troubles? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2012, 09:24 PM
I have a Carter AFB 9635SA Carb that has been giving me a headache, it has a rough idle and a miss and pop. It's on a 326 engine it has electric choke and it's opened up, I have cleaned it 3 times, soaking and then blowing out with air. installed 2 kits in it and have checked myself twice before assembling, making sure it's right. Still has a rough idle, I have to back out the mixture screws 3 turns to get it to idle and turn the idle stop screw in 2 full turns so it won't stall. it's sputtering at the exhaust.
I have it at stock configuration which is the same as an Eddy 1406.
What could be ailing this carb?
Is it worth it to try and get it right?
Or move on?
Old 08-24-2012, 08:26 AM
RWENUTS's Avatar
You again!!! LOL!!!
What intake?
What's your timing set at?
Old 08-24-2012, 08:45 AM
My timing is set to 6 BTDC, Eddy Performer intake.
I am still trying to get it running, it does run good with other carbs on it.
This one has troubled me for awhile now, it was the my first one that won't run good
Old 08-24-2012, 10:28 AM
RWENUTS's Avatar
Spreadbore intake and squarebore carb. What do you have for a gasket between carb and intake?
Bump your timing up to 12*.
Old 08-24-2012, 10:50 AM
I have a gasket with 4 holes in it for a Carter AFB and a 1/4" 4 hole spacer made for Carter/Edelbrock it's like a heat shield.
So what are you saying I should be using a Q-jet on this intake?
Bump my timing to 12 BTDC, It's a stock 326 with a Comp Cams close to stock?
I asking why I should, will it her anything
Old 08-24-2012, 11:30 AM
Fang16's Avatar
Poping out of the carb usually means it's running lean. check for vacum leaks esp around the two base gaskets.
The Following User Says Thank You to Fang16 For This Useful Post:
raguza123 (08-25-2012)
Old 08-24-2012, 01:29 PM
RWENUTS's Avatar
When going from a spreadbore intake to a squarebore carb you need an adaptor like eddy #2732 or you get a vacuum leak along the sides.
And try 12*. My stock 230 six banger luved it. Won't hurt anything except your wallet. You'll get better mileage and save some money.
My tweaked 350 sbc I had with aluminum heads, big crane cam, headers etc used 22* initial. It's the crap gas you buy now.
Edelbrock.com - Installation Items - Adapters & Spacers
The Following User Says Thank You to RWENUTS For This Useful Post:
Old 08-24-2012, 01:55 PM
It's not popping out of the carb. it's sputtering out of the exhaust
Old 08-24-2012, 01:59 PM
I have an adapter plate made for the Carter's to adapt it to this manifold, and I don't have a 12 BTDC mark on my engine, I would have to guess at it.
Old 08-24-2012, 04:05 PM
RWENUTS's Avatar
Put a timing tape on it.
You got a pic of your adaptor?
Old 08-24-2012, 04:24 PM
you buy them on ebay as a heat shield they are built to the type of carburetor. Carter, Qjet, so on so on
I get one for you
I install a gasket on the manifold then the spacer and a gasket on the top of spacer then carb. all have 4 holes in them.
Old 08-25-2012, 08:15 AM
RWENUTS's Avatar
Well that should work just like the eddy one.
I think you need to decide on a carb and fine tune your combo.
Take a pic of the timing tab on your motor for us!!!
Old 08-25-2012, 08:33 AM
He's a pics for you, the center line is 0 and top is a 4 ATDC and the bottom is a 6 BTDC, this is all my cover has on it.
I was trying to get it running good again, it's what started me looking for a better carb, which I have now.
Maybe the 9635SA is beyond repair and is ready for retirement, I know I have been trying to for the last 4 or 5 months now get it running good and it won't, and while testing out different carbs.
Old 08-25-2012, 01:50 PM
JeffB's Avatar
Print this and save it: http://www.mymopar.com/downloads/carterafbtuning.pdf one of the first things you might try as you don't need to go into the Carb is changing the pump shot,check out that section first.
The Following User Says Thank You to JeffB For This Useful Post:
Old 08-25-2012, 03:25 PM
I don't think the pump shot would make it idle like crap, it idle has a miss and sputter out of the exhaust, and smells rich, I have to backout the mixture screws to 4 turns so it'll idle with less sputtering amd misses.
I tried carb cleaner around the base, all vac connections and the ones with plugs in them. no idle change.
Just a lot of sputtering, won't even think of road testing, but acceleration has no lag.
I am just puzzled
Carter AFB conrad854 Engine 4 11-06-2011 05:51 AM
Carter AFB marybill Engine 5 07-27-2010 07:38 AM
Carter AFB Preformer Series (9635SA) Mike McGee Engine 1 11-30-2008 10:24 AM
carter afb briced Engine 2 10-30-2008 01:53 AM
Carter Afb ED&SUE General Rodding Tech 5 10-17-2004 11:59 AM
