carter AFB ... any tips? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2004, 02:04 PM
Fizz's Avatar
I have a Carter AFB in my Cad. SDV 1964, which i dont really like ...
Some Cadīs of the same year model has Rochester Q-jet ...
Is that a better or worse carb.?
Is there any other good replacement carbs, or should i keep the AFB?
I mean, they still build them (Edelbrock) so they cant be that bad?
Old 04-25-2004, 02:31 PM
Jmark's Avatar
From my experience, the Carter AFB was the most dependable trouble free carb i've owned. Had 2 on both trucks. Mine went 140,000 with not so much as a rebuild. I had the 600 on each.
After rebuilding both engines, we decided to go with the Q-jets. The Q-jets have a higher cfm rating so they do run better. Unless you plan on buying a NEW Q-jet, finding a good core is hard as they are now pretty old and hard to find in good condition. eBay is loaded with Q-jets but you don't know what shape the throttle plate and shaft is in, so a re-bush may be in order.
Mark
Old 04-25-2004, 03:06 PM
Fizz's Avatar
that sounds nice ....
i have a factury remanufactured carb, so i suppose itīll last
a few miles ...
i only drive the car 1000-2000 miles per year ...
short summer over here, you know... =)
