Carter AFB boost referencing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2011, 04:16 PM
In a blow-thru turbo setup using a Carter AFB, how are the needles boost referenced? Of course, the AFB's use a needle and jet rather then a power valve like the Holley's, but they both work in the same way. Since the Holley power valve needs to be boost referenced, one assumes that the Carter needles will also need referencing.
But how..? Anyone know?
Old 04-09-2011, 05:18 PM
techinspector1's Avatar
Wiki Edits: 326
AFB/Edelbrock....
http://www.theturboforums.com/smf/in...;topic=22107.0
Holley....
http://www.hangar18fabrication.com/blowthru.html
Old 04-10-2011, 04:46 PM
Thanks, but neither link discussed enrichment under boost. The Hanger discussed in but for Holleys only. Any other ideas?
Old 04-15-2011, 09:04 AM
Overdriv's Avatar
In a blow thru situation I though you enclosed the whole carb in a box. That way the carb is in the same atmosphere as the incoming air.
Boost referencing power valves. 427blownvette Engine 5 12-31-2010 09:25 AM
Boost referencing a BG 750? 72GMCTruck Engine 1 11-07-2010 09:29 AM
should i run a boost or boost 30inHg/20psi gauge ftpro2 Electrical 1 02-04-2008 10:27 AM
cross-referencing champion 8819's to bosch.... sc2dave Engine 2 07-30-2007 07:35 PM
need some cross referencing of leaf springs TooMany2count Suspension - Brakes - Steering 1 10-02-2003 08:21 PM
