carter afb carb ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2010, 04:06 PM
carter afb carb ?
hi guys
i just got a gm performance crate engine and i hooked everything up and i put my old carter afb carb on it and its on a nascar ram air manifold my problem is that when i take off on the street it pops and then sometimes stales out but if i take off slowly with little throttle its works perfect its only when i give it full throttle from a dead stop.
dose any one have any ideas for me what it could be ?
thanks
dan
Old 05-27-2010, 04:51 PM
sounds like not enough or no accelerator pump. And also I would check to make sure the timing is right. look down into the carb with the motor not running and see if there is fuel squirting out when you hit the gas.
Old 05-29-2010, 09:59 AM
carter afb carb ?
hi checked and im geting 2 squrts comming out when i move the throttle linkage back and forth with out the moter running and i set the timeing to what the motor called for
any other ideas
thenk you
dan
Old 05-29-2010, 10:09 AM
377tk's Avatar
afb issues
It could still be the accelerator pump is putting out but not a strong signal. It also could need to be re calibrated. I would put a $30 rebuild kit in it and start there then you will have a good foundation to start with. Then if it still does it buy a recalibration kit from edelbrock.
Old 05-29-2010, 10:38 AM
could be a vacuum leak. but almost always it is a lack of accelerator squirt to cover the instant lean condition under instant full throttle. and also I've had car s that you had to step down on the gas not just slam it for best take off. also what is a nascar ram air manifold? If it is a single plane on a mild motor you will never get rid of the off idle bog, there is just to much hole to fill with out enough flow. It will run ok but you cant expect great off idle response.
Old 06-04-2010, 03:46 PM
carter afb carb ?
a nascar edition rpm air gap manifold is nothing more then just a edelbock performer series & thunder series avs square -bore.
Old 06-04-2010, 03:51 PM
carter afb carb ?
http://www.jegs.com/i/Edelbrock/350/75013/10002/-1
Old 06-04-2010, 03:54 PM
carter afb carb ?
also i pulled a plug and keep in mind i put all new plugs in when i first started the engine . well any way it was black and had some wetness on it .
dose this mean i am running to rich ?
if not dose any 1 know what it could be ?
thenk you guys
dan
Old 06-04-2010, 08:32 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Herre is a downloadable file on tuning a Carter,
http://www.carburetor.ca/pdf_manuals...BSelection.pdf
Carter Tech Info,
http://www.carburetor.ca/carbs/tech/index.html
SERVICE AND TROUBLESHOOTING TIPS
http://www.thecarburetorshop.com/Troubleshooting.htm
Exploded View of a Carter model AFB Carburetor
http://www.carburetorfactory.com/expvw04.html
Luv the smell of NITRO in the morning.
Old 06-05-2010, 01:01 AM
Edelbrock PN 1475. Your accelerator pump nozzles are too small.
Old 06-05-2010, 01:05 AM
You'll probably need a tuning kit too. Edelbrock
Old 06-14-2010, 07:21 PM
thewrongshop@yahoo.com
Carb, Miss, And Runing Hot
THE CARB WORKED GREAT ON THE OTHER ENGINE AND THE PROBLEM
ISN'T THE ACCELERATOR PUMP IT'S THE LINKAGE THAT IS MISSING THAT GOES TO THE PUMP SHAFT . M.O. I WOULD PUT MONEY ON A HEAD GASKET SINCE IT MAY HAVE RAN OVER 230+ , THE PROBLEM IS NOT PLUGS OR A CARB , IT WAS THE WAY THINGS WERE PUT TOGETHER WITH TOO MANY HANDS IN THE POT .
HOPE YA DIDN'T PUFF A HEAD GASKET THERE DAN... I TOLD YOU IF YOU NEEDED A HAND TO CALL ME ...... I'LL BET IF YOU PRESSURE TEST THE COOLING SYSTEM YOU'LL SEE A RISE OVER 19+ LBS. BEFORE THE FAN TURNS ON AND THEN OFF & THE UPPER HOSE IS A HARD AS A pvc PIPE.
Edelbrock VS Carter AFB hollywood2k Engine 22 04-03-2012 06:20 AM
old carter AFB rods or jets? fast68 General Rodding Tech 6 10-18-2009 09:16 PM
Carter AFB WOT tuning 70bird Engine 4 08-20-2008 11:28 AM
Carter AFB Carb: Little Ball Bearing Fell Out Of Somewhere Can't Find It's Home Brawler Engine 7 06-12-2007 05:15 PM
carter AFB ... any tips? Fizz Engine 2 04-25-2004 03:06 PM
