Carter AFB Carb: Little Ball Bearing Fell Out Of Somewhere Can't Find It's Home - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2007, 06:56 PM
Anyone know where that damn little bearing is supposed to go that and a little brass lookin piece that is squared fell out when i tipped it upside down while taking it apart if anyone knows where they go the knowledge would be greatly appreciated.
Thanks.
Old 06-11-2007, 07:07 PM
Last journal entry: A few ongoing projects
It's the check valve that goes point down under the accelerator pump nozzel.
Old 06-11-2007, 07:47 PM
Thanks For The Quick Reply
Thanks 1957plymouthhemi for responding so quick i'm not quite sure what goes where and point down? I have a small round ball bearing and a little gold coloured squared pice of metal witch i think go under the piece with the two jets in the front of the carb is that what u mentiond and if so what order do they go in?
Old 06-11-2007, 08:12 PM
woodz428's Avatar
Troll Hunter
I would guess that the ball drops into the hole inside the pump chamber and the little tin piece is supposed to be placed on top and swedged under tabs cast into the body to keep the ball from coming out.
Old 06-11-2007, 08:36 PM
OK I thought you just had the pointed check valve. The ball drops in the hole first, and the square piece drops in after it (It acts as a weight on the check ball to seal the hole so the accelerator pump will not suck air). They are just dropped in to the hole.
The piece you removed from the front of the carb with 1 screw that has 2 nozzels that point into the front carb bores is where it goes. When this piece (the accelerator nozzel assembly is in place and screwed down it is what keeps the ball and weight in place.
Old 06-11-2007, 08:50 PM
Pretty Sure I Got It Now
thanks again for your quick responses i figured thats where they had to go so i dropped em in and was hoping you would say that was the right way. I was so carefull taking it apart but they must have been stuck and then freed during the jiggle upside down lets just hope it goes back together ok.
thanks again.
Old 06-11-2007, 09:40 PM
woodz428's Avatar
Troll Hunter
Originally Posted by 1957plymouthhemi
OK I thought you just had the pointed check valve. .
and I thought he was referring to the ball under the pump, not under the nozzle.
Old 06-12-2007, 04:15 PM
DOUBLEDICK's Avatar
This should help.It is an Edelbrock but it is the same as the AFB
Name:	scan0002 (537 x 742).jpg
Progress on 37 Ford Coupe DarellGLewis Hotrodders' Lounge 28 08-31-2005 07:27 PM
I need help finding gaskets for Carter Carb.... onebadmerc Engine 2 11-29-2004 02:13 PM
Carter carb identification newchevyman Engine 2 12-16-2003 09:18 PM
Where can I find this carb? (QJet) 78SilverShark Engine 7 08-14-2003 03:07 PM
