Carter AFB carb Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2002, 03:29 PM
Post Carter AFB carb Question
I recently picked up a new Carter 625cfm carb very inexpensively, problem was it has Mopar linkage and I need a chevy is there a way to convert this or am I stuck with a mopar carb?
Old 10-12-2002, 04:10 PM
Post
Try going to jegs.com and look up part number 720-3830G to see if this will work with your application. If not they have others.If that does not help try Emailing customerservice@jegs.comwijth jour problem and they will tell you if they can help.
Old 11-10-2002, 10:23 AM
Post
Check with Edelbrock, since they have basically remanufactured the carb, I'm sure they would have the appropriate linkage.
