Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carter AFB Carburetor Identification and rebuild kit
Old 09-04-2012, 09:56 PM
keitho64's Avatar
keitho64 keitho64 is offline
Last journal entry: 1969 Porsche 911 ( IROC Clone)
I am trying to identify a carburetor I have for a Corvair project I am working on. It is a Carter AFB (embossed on the casting) and there is also a tag on the carb with the numbers 2632 and 42009. It is setup with a manual choke.
I found some information that shows it could be a carb off a late 50's Chrysler with dual quads and it is 400CFM. However the number should be 2632S and mine is just 2632. I hope it is a 400CFM as that is what I would like to try.
Do any of you know a place that can assist identifying the carb?
Do any of you know what rebuild kits may fit?
I am a novice with Carter's. I have worked on Edlebrock's (which are Carter AFB 9000 if my memory is correct), Rocherster's and Holley's but never an old AFB Carter.
Thank you,
Keith
