Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carter AFB Carburetor Identification and rebuild kit
Old 09-05-2012, 12:47 PM
raguza123 raguza123 is offline
Be careful with this one as it has longer metering rods, how I can tell is next to the air horn opening is a screw and a little cover and it has a raised up spot for the power piston.
It also has no secondary air valve like the other AFB's, so you may get a secondary bog, Jetting may need to be reworked a little.
