carter afb comp carb hose connections - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2010, 09:20 PM
dorrsulee
Last journal entry: 1938 cadillac frame off restore
I have a carter afb competition carb with two hose connections on the top plate drivers side.. The rear one feeds the float bowl. what is the front hose connection used for?? There is a lower front connection I assume is for vacuum.
Old 10-29-2010, 11:26 PM
SSedan64's Avatar
Both may be for Bowl vents, 1-in, 1-out. Smog setup for fumes? Just a guess.
I remember some of the old 4010/4011 Holley carbs for Dodge's had large vent tubes on front & rear.
Old 10-30-2010, 12:13 AM
mud.man.rj's Avatar
carter crb
The top back left corner is for fuel, any other on top are vents do not plug. The front lower in the middle is a vacumn port for pcv valve in valve cover. The same is usually in the back but may have a plug and is for brake booster.
Carter Competition AFB HPfreak Engine 6 05-06-2010 06:47 AM
Carter AFB WOT tuning 70bird Engine 4 08-20-2008 11:28 AM
Braided fuel hoses all leak gas vapor odor? Steve S Engine 2 04-26-2007 10:52 AM
carter AFB ... any tips? Fizz Engine 2 04-25-2004 03:06 PM
Carter AFB carb Question beaver24 Engine 2 11-10-2002 11:23 AM
