carter afb, dies after mid to heavy throttle.
I have a 351 with a carter AFB carb. I started with adjusting the timming then went to carb adjustments, idles great, has great response while garaged, but put it on the road and engine dies after mid to heavy throttle, starts right back up imiediatly and wont run smoothly without feathering the throttle. To my knowlage this carb has not been rebuilt. 78 Ford highboy. any ideas before i start the carb rebuild ? thanks.
Jeff, thanks for the reply and tips, ill roll with your advise and see what happens.
Good advice above, but also check the fuel filter(s). Some of the older Carters, especially if it was originally a GM version also had a porostone filter at the inlet which can cause no end of problems to the uninitiated
| engine dies or stubbles after i blip the throttle | boredandglued | Engine | 2 | 05-15-2010 10:08 AM |
| 305 Dies flat on face at sustained mid throttle | dukeofwsu | Engine | 11 | 03-23-2010 10:04 PM |
| M4ME carb stumbles sometimes dies when letting off throttle in gear | fast68 | Engine | 4 | 08-29-2007 05:57 AM |
| Odd throttle respone at startup/engine dies | 71gtx | Engine | 5 | 11-30-2005 12:21 AM |
| Throttle Control..Cable / Lever & Rod/ Or Electronic ( Throttle By Wire) | Viet Nam Vette | Engine | 4 | 06-13-2005 04:29 PM |
