Carter Carb?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2005, 12:21 PM
85citation's Avatar
Life's a small bore.
Last journal entry: The engine's in!!
Carter Carb??
Hey, I'm back!
I have a 2 BBL carter from a 68 Chrysler, carb # 4423S. I am building an adapter plate to mount it on my 3.1L conversion (3.1 with 2.8 top end). The problem is I need to redirect the throttle links by 90 degrees.
Is there a kit available to move it around? I don't have room to move the cables (throttle and automatic tranny), but I do have a machine shop available to me. I can build what I need, but I'd rather get something that looks custom.
Also, I need an air breather that is 1.5" tall for a 4.25" throat.
Thanks.
Life is a bore.
It's up to you if it's a small bore or a big bore.
Old 04-19-2005, 01:21 PM
poncho62's Avatar
Wiki Edits: 5
Why..........the stock Citation carb will work better. I could see if you wanted to go to a small 4bbl.................
Old 04-20-2005, 06:49 AM
85citation's Avatar
It's on my Olds Omega (see my journal). The carb is toast, and a small 4 barrel setup is too large for this engine. I couldn't close the hood with one, and I don't want to hack it. the 2 BBL has a little more than enough flow rate for this engine without drowning it in gas.
Thanks.
Life is a bore.
I need help finding gaskets for Carter Carb.... onebadmerc Engine 2 11-29-2004 02:13 PM
Carter carb identification newchevyman Engine 2 12-16-2003 09:18 PM
Edelbrock Carb Chadman Engine 17 12-09-2003 01:10 PM
Carter carb ID? Ohio-Dan Engine 0 03-07-2003 09:01 PM
Carter AFB carb Question beaver24 Engine 2 11-10-2002 10:23 AM
