Carter Carb Experts - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2006, 10:18 PM
MI2600's Avatar
Member# 3287
Carter Carb Experts
Need some help. I came across a Carter AVS carb today, # 4028S. It came off a '66 Caprice 327.
A Google search confirmed a 4028 (no S) was factory on a 275hp 327.
This is the wierdest Carter I've ever seen. The fuel inlet is on the back, not on the back corner like all I've ever seen. Also, on the top near the accelerator pump there is some sort of maybe vacuum release gizmo. The rest of the carb appears to be normal Carter/Edelbrock.
Anyone know more about this carb...cfm, other applications?
Thanks in advance.
Old 08-05-2006, 02:52 PM
MI2600's Avatar
Member# 3287
Aw, c'mon guys. There's got to be someone out there that knows something about this carb...or maybe has a reference book.
Old 08-05-2006, 03:02 PM
Marcel
Last journal entry: Choo-choo town
carter carb experts
could we see a picture of this monster?
Old 08-05-2006, 04:20 PM
MI2600's Avatar
Member# 3287
I've got it apart, but I can put enough together to give you an idea.
Old 08-05-2006, 04:31 PM
MI2600's Avatar
Member# 3287
Pic #1: Standard front view.
Pic #2: Passenger side and rear inlet.
Pic #3: Screwdriver pointing to gizmo...maybe vacuum release?
Pic #4: Standard driver side linkage.
ID:	13916   Click image for larger version
ID:	13917   Click image for larger version
ID:	13918   Click image for larger version
Old 08-05-2006, 04:52 PM
Marcel
The carb.
i played around with a lot of chevy small block in the 60's, but i an't never seen one like this one. the gizmo ,i think is a vent for the float bowls, is it not over the bowl on the drivers side. The high speed idle is on the back instead of the left ( driver side) front. if its not some kind of Canadian cross over, i'm lost. hope someone else can help, if find out, I'd like to know what it is.
Old 08-05-2006, 09:53 PM
MI2600's Avatar
Member# 3287
Two reference sources now have id'd it as a 275hp 327 carb, but beyond that I'm lost.
Anyone?
Old 08-06-2006, 12:29 AM
malc's Avatar
Living At The Speed Of Life
I looked around yesterday and came up with Rebuilt Carter Carburetors the pics are´nt that good, maybe you could contact them.
Old 08-06-2006, 10:07 AM
MI2600's Avatar
Member# 3287
Thanks, Malc, good idea. The rebuilders probably know more about this one. It appears to be an oddball.
Old 08-07-2006, 05:56 AM
engineczar's Avatar
We ran one on our Stock Eliminator car for years back in the 90's. Not that exact model number but an AVS none the less. The ones we ran didn't have that device you're pointing at but I would agree that it's a vent of some sort.
Old 08-07-2006, 08:32 PM
It looks a lot like the bowl vent on an old Q-jet, so that'd be my guess. The factory probably just requested some extra or unique non-standard features when they contracted for a supply of AVS carbs.
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Calling all carb experts Bob88 Engine 27 05-01-2005 09:50 AM
What Came first Chicken or the Egg, or Carb Adj vs Timing riesman20 Engine 19 07-18-2004 10:26 PM
Calling all tri carb experts eric302 Engine 10 07-15-2003 09:59 AM
rochester 4 jet carb, rich Walker Engine 2 07-13-2003 09:42 AM
