Carter Electric Fuel Pump ID? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2008, 08:53 AM
BT74's Avatar
The PO of the Willys Pickup I'm working on (powered by a SBC w/2bbl). Installed a Carter vane type aftermarket fuel pump due to a clearance issue with the mechanical pump. This Carter Electric pump is obviously running at too high a pressure and flooding out the carb (freshly rebuilt by a highly reputable local shop). Carter apparently marketed a number of identical looking pumps with various output pressures, but the # on the pump body does not correlate to any of the models I find in Jegs or Summit. The body has a green label that has : P/N 152-675 on it. But I can find no reference to that part number? Anyone have any ideas? Thanks
I realize I need a regulator, but the regulators appear to work within specific input pressure ranges.
Old 05-12-2008, 11:23 AM
Wiki Edits: 31
a picture would be helpful.. I know the GLS series pumps all look identical but diffrent numbers for diffrent preassures.. the GLS 393 ( pump that comes with the Holley 670 fuel injection kit ) is factory set to 15 PSI, the GLS 392 is factory set to 45 PSI.
Old 05-12-2008, 04:44 PM
techinspector1's Avatar
Wiki Edits: 326
What I would do is sell the pump you have and buy this 180-P4070 pump from Jegs......
http://www.jegs.com/p/Carter/748050/10002/-1/10307
4-6 psi and no regulator required.
Old 05-12-2008, 07:49 PM
BT74's Avatar
Thanks guys, as for a picture....the 180-p4594 pump in the link looks exactly like whats on my willys, but there is no coresponding number on the pump.
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 06:28 PM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 10:47 PM
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 03:54 PM
HELP QUICK Electric Fuel Pump Leaking 66 T-Bird Engine 4 06-06-2005 07:26 AM
electric fuel pump recommendations stea Engine 2 06-27-2004 09:38 PM
