carter intake manifolds - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 10:23 PM
I was talking to a guy yesterday thet mentioned he had two Carter intakes for SBC. I did some searching online and can't find any info on them just wondering if it is worth looking into and if they are decent from a performance aspect.
Old 06-13-2010, 11:27 PM
techinspector1's Avatar
Wiki Edits: 326
I suspect what he was saying is that he has two intake manifolds that will mount square-bore Carter carburetors, as opposed to spread-bore carburetors like the Quadrajet.
Old 06-14-2010, 06:50 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Carter WCFB was a "small" bolt pattern Carter carb. They were used alot before the AFB and square bore Holley came along. The dual four SBC up to the early 60's used them, even w/two of them, the total was less than 800 CFM. They all could be considered to be "air valve secondary" carbs, although "AVS" as a term wasn't used until relatively recently, IIRC.
IIRC the WCFB shared the same bolt pattern as the Holley 6000, aka "Flaming Toilet Bowl":
Below is an adapter that shows the difference in the bolt patterns between the WCFB (inner) and the square bore (outer).
pontiac 400 Intake manifolds 68Birdman2 Engine 3 05-25-2010 11:03 PM
Biggest air filter on 2X4 intake manifolds? xxllmm4 Engine 3 06-08-2009 10:01 PM
eBay Chevy intake manifolds DENCOUCH Engine 59 02-25-2009 08:15 PM
Intake Manifolds Dual plane Vs Single Plane chevy_power427 Engine 20 08-05-2008 04:00 AM
port matching the intake. Jmark Engine 9 12-08-2003 10:13 AM
