Carter P4070 Electric Fuel Pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2007, 09:35 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Does anybody have the dimensions (preferably without the fittings installed) on the Carter P4070 fuel pump? Also, with this pump's max pressure of 6 psi, is there any reason to install a pressure regulator with this pump to feed an Edelbrock carb (1405 or 1406)? Many thanks in advance to all who reply.
Old 05-11-2007, 07:12 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
The pump is basically round and is 3" in diameter. The distance from inlet boss to outlet boss is 3 3/8". If you use the supplied bracket, the distance from the face of bracket (mounting surface) to the centerline of inlet/outlet fittings is 1 5/8". Overall height, from electrical connections on bottom to mounting nuts on top is 6". The pump puts out an honest 6 psi and I have used this on an Edelbrock 1405 with no problems.
Hope this helps,
Steve
Old 05-11-2007, 08:43 AM
Steve - this is exactly what I wanted to know. Could not find the dimensions on that unit anywhere. Much thanks.
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Can I run a small electric fuel pump w/6v system 40chevy Electrical 12 05-01-2006 11:16 AM
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 02:54 PM
electric fuel pump recommendations stea Engine 2 06-27-2004 08:38 PM
electric fuel pump slammer10 Engine 4 10-26-2001 05:08 PM
