-   -   Cast 400 sbc crank (http://www.hotrodders.com/forum/cast-400-sbc-crank-2819.html)
tjk2000us2000 06-28-2002 07:20 AM
Cast 400 sbc crank
How much power can a cast GM 400 cid. crank take?
Tim
wrenchturner 06-28-2002 01:16 PM
Id say it should be good up around 500 hp.just a opinion (wrenchturner) ;) :)
Tom 06-28-2002 07:02 PM
use longer rods in the 400 and the crank won't take as much pounding,check the cam to rod bolt clearence if you do.it will also increase torque significantly
JdOwNj 06-29-2002 05:18 AM
Not much!
