Cast 400 sbc crank - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2002, 08:20 AM
New Member
Post Cast 400 sbc crank
How much power can a cast GM 400 cid. crank take?
Tim
Old 06-28-2002, 02:16 PM
Post
Id say it should be good up around 500 hp.just a opinion (wrenchturner)
Old 06-28-2002, 08:02 PM
Tom Tom is offline
Post
use longer rods in the 400 and the crank won't take as much pounding,check the cam to rod bolt clearence if you do.it will also increase torque significantly
Old 06-29-2002, 06:18 AM
Post
Not much!
