Cast flywheel safe for street use? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-14-2011, 07:21 PM
Why not just take it easy on it,save up buy the good flywheel & then hammer on it?
Shane
  #17 (permalink)
Old 03-14-2011, 09:07 PM
I was thinking of that also because the clutch is not as high quality as I would like so it'll need to be changed sooner than later.
From what I've read the scattershield will hold the flywheel if it disintegrates saving my feet possibly my life or someone else's, I think this is what I was originally after. However what I've learned along the way is that if the flywheel goes it may take the trans with it and the scattershield will be junk. I'm going to have to change it or I will worry about it every time I wind it up.
On a separate note, some cast flywheels are not actually cast iron. I'm told the mustang ones from the late 90's are actually sintered iron which is alot stronger. So when some people were telling me they run a cast flywheel, it's not exactly the same.
Thanks everyone for your input.
  #18 (permalink)
Old 03-15-2011, 07:07 AM
You can get billet flywheels for under a hundred bucks on ebay,but I do not know what the quality is like.
Shane
  #19 (permalink)
Old 03-15-2011, 10:44 PM
I had a look at those, no hint of an sfi rating not sure I would trust it. I'll just save up for the good one I think. Thanks
  #20 (permalink)
Old 03-16-2011, 03:42 AM
3rdmember
couple hundred buck for peace of mind is worth it to me...
at least you're building a chevy, amc stuff is way out there..
i've got well over 600 in mine (McLeod aluminum +balancing)
oh yeah, if you're not already, run a block plate
  #21 (permalink)
Old 03-16-2011, 01:08 PM
Yeah the block plate came with the lakewood.
Going fast ain't cheap
Safe RPM limit for stock cast flywheel (SBC) v8hed Engine 8 03-05-2010 07:05 PM
HELP 454 flywheel cast#3973457 Fastest65 Transmission - Rearend 0 02-25-2009 04:40 PM
7,800 RPM stock cast iron flywheel explosion! Huskinhano Engine 35 11-02-2005 12:15 AM
use of aluminum flywheel on the street..thoughts 357f-150 Transmission - Rearend 11 12-23-2004 12:10 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
