Cast iron 15 degree heads?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2006, 01:39 PM
Sudden Psycho 31's Avatar
Hello all,
this maybe a crazy one... but I am looking for info on a 15 degree - ls6 style head to use on a iron gen3 block. Our local track has a few very few restrictions on engines, except it must be all cast iron, (heads and engine).
So i am looking at all options, there is much advantage to 15 v. 23 that it sparked my interest. don't get me wrong, i love the big ol' rompy (1000 rpm idle 6in. vac.) engines that i have now, but i want to try some of newer technology.
Thanks for reading...
Old 11-08-2006, 01:51 PM
Same rules we have, I believe one or two years of the 6.0 truck engine was all iron. should make good power and live with the way the bottom end is set up.Check 99-01 trucks I think.
Old 11-08-2006, 02:55 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Correct me if I'm wrong but I believe all regular production Gen III/IV engines have 15 degree valve angles. And I think the new LS7 engines have a either a 12 or 13 degree design. I'm pretty sure they left the 23 degree heads behind when they went to the new engines.
And yes, there were a couple years where the pickups used iron heads. I know my '00 6.0 has iron heads on it and possibly the '01s too. I'm not exactly sure when they started going to aluminum.
Old 11-08-2006, 03:44 PM
RippinRon's Avatar
I work at a used car dealership and we have a half dozen or so late model gm trucks and vans i'll check under the hood tomorrow and tell ya what I find. I kinda of think all trucks have iron heads.
Old 11-09-2006, 06:10 AM
thanks ahead rippin ron,
That would be a great help.
Not many of those trucks make it to the u-pull its yet.
I know that the new trucks lq9 (and lq4 i think) 6.0 engines are cast blocks with aluminum 15 degree heads.
I think the first 6.0 truck engines would be the iron ones.
Thanks, Brian
Old 11-09-2006, 11:28 PM
Blazin72's Avatar
Wiki Edits: 19
Psycho, the 99-00 6.0s for sure have iron heads.
What engine do you have now that you want the heads for?
Old 11-15-2006, 10:13 AM
As of yet, i do not have any. That will change soon, when we can get our hands on a couple of gen iii cast truck blocks. I am just stepping into the newer blocks and looking for info. I have already learned a bunch since starting this thread. Can't wait to try em on the track.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Hey Barry, Hey Martin 15 degree rule AC/DC Body - Exterior 15 02-01-2006 08:13 AM
small block ford cast iron heads k-star Engine 20 12-10-2005 08:35 AM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 08:26 PM
Brake parts cast iron or cast steel brainsboy Suspension - Brakes - Steering 0 05-26-2004 03:42 PM
