cast iron headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2007, 09:49 PM
cast iron headers
My gen v 454 exhaust manifolds have lumps cast on the top inside of the header. Another set of big block manifolds have the same type of material but they are drilled (for air injection?) but these ones are out of a truck and are not drilled and tapped. My question is whether I should grind them out for better flow.
Clint
Old 11-26-2007, 10:53 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
You can, but it won't do much good. For the cost of a good set of headers you can gain way more good flow. Manifolds are bare minimum flow. The best you can do with stock manifolds is port them, but the work involved for the minimal increase in power isn't worth it.
If they're off and you have some abrasives, go for it, but don't expect more than 2 hp or so. For the work involved and the cost of abrasives, you'll never feel a difference. Save up for headers.
1955 cast iron powerglide slingslingbinks Transmission - Rearend 8 09-11-2008 08:53 PM
Cast Iron Heads El Co 406 Engine 3 08-29-2007 08:50 PM
welding cast iron 53LEDSLED General Rodding Tech 40 11-03-2005 12:39 PM
Cast Iron Crankshaft RPM Limit ? bigjoedo Engine 6 11-24-2002 03:49 PM
allum. vs. cast iron heads in a daily driver? solowookie Engine 4 02-06-2002 05:26 PM
