Cast Iron Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2007, 12:39 PM
Cast Iron Heads
Last question for today. I was given a 350 and am trying to decide whether or not to work with the current heads. They are cast iron stocks with the casting number 3991492. Are there any benifits to using cast iron heads and has anyone used 492 with any sucess? The engine will most likely be dropped into a late 60's/early 70's Chevelle. I'm looking for decent power, but nothing too drastic that would be unreliable or needs constant work.
thanks
Old 08-29-2007, 12:48 PM
These are exellent stock heads 64cc large valves, capable of well over 400 horsepower.However that being said if they need a lot of work vortecs would be a better option money wise.But if they are good shape and you are not building a record setting car use em.Oh by the way you will probably get many replies saying junk'em and get new aluminums or vortecs or whatever old tech is junk.I call B.S these old heads rock and rolled.
Old 08-29-2007, 01:03 PM
They have been sitting on an old 350 unused for about 8-10 years, I'm thinking of having them hot tanked and checked for cracks since they sound like they can put out the power I'm looking for.
Old 08-29-2007, 07:04 PM
F-BIRD'88's Avatar
Yada Yada Yada
One of the best factory heads to start with. You can create a very good street performance motor using these heads.
Old 08-29-2007, 08:50 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Runners are 157 intake, 62 exhaust. Valves are 2.02"/1.60". Flow figures taken from info by Stan Weiss are as follows:
0.300" valve lift 173/125
0.400" valve lift 198/137
0.500" valve lift 206/141
Dart Iron Eagle or Vortech Heads bigjoedo Engine 31 05-14-2013 05:36 PM
Aluminum vs. Cast Iron heads 69novarodr Engine 128 04-30-2005 08:47 AM
Dart Iron Eagle Platinum heads. Sagacious Engine 1 04-27-2005 08:24 PM
What Dart Iron Eagle heads are right for me? batman09 Engine 2 09-11-2004 09:25 PM
allum. vs. cast iron heads in a daily driver? solowookie Engine 4 02-06-2002 05:26 PM
