Cast iron heads question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2010, 01:33 AM
Can I port my 624 casting sbc heads with 1.94 &1.5 to perform well? Block is .30 over
Old 06-24-2010, 06:38 AM
BOBCRMAN@aol.com's Avatar
I would not waste my time on 624 castings. These are some of the worst SBC heads. Light weight , VERY crack prone.
Old 06-24-2010, 06:45 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There was a 428624 head that might not be as bad as the crack-prone 462624.
The 428624 also had 1.94" x 1.5" valves, had 76 cc chambers and was used as far back as '69 according to the numbers I'm seeing.
Good luck.
Old 06-24-2010, 05:23 PM
thanks cobalt327
mine are the 462 dangit appreciate the knowledge many more questions to come!
Old 06-24-2010, 05:26 PM
thanks BOBCRMAN
saved me alot of time and money... more questions to come
After-market Cast Iron Heads for 406 SBC SeniorRodder Engine 2 06-13-2010 04:47 PM
Hyd roller cam with iron heads. Stonebrier 2 Engine 7 06-06-2010 06:32 PM
SBC '87 + Cast Iron Heads VS Older intake '55-'86 monzter Engine 9 04-02-2010 09:07 AM
Question about older Pro Topline Heads Blazer79 Engine 3 01-03-2010 05:10 AM
Cast iron powerglide slingslingbinks Transmission - Rearend 13 09-30-2004 11:18 PM
