cast iron high rise dual plane sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2012, 06:10 PM
I have a 72 chev p-u. It has a 355, flat top four valve relief,s forged pistons. 194 camel hump heads. hei. headers, holley 650 vac sec. It has a cast iron high rise dual plane, with a bow-tie emblem bhind the carb. I think its off a boat. i seen one on craiglist, it said it was off a boat. Is this a good intake for my combo. i have a 87 later performer dual plane, can it be used if i redrill the 2 center bolt holes, my brother said it may work. will it, and will it help my combo? oh yea It has a very lumpy solid lifter cam, dont know the specs. but it is pretty big judging from the sound at idle.
Old 11-06-2012, 10:05 PM
vinniekq2's Avatar
sound at idle is not a complete story teller about the cams size
Old 11-07-2012, 12:21 PM
hcompton's Avatar
Old & Furious
Like the others side it ok but very heavy not sure how much but some stock intake are crazy heavy. I thought i had forgotten a bolt when i took the stocker off my poncho. Nope it was just 40 or so pounds of intake.
Go with the performer. Not a bad way to go. Center bolt holes can be drilled. i have seen very ugly jobs work without leaks. Best to do it right but it should not be an issue. Check ebay half the intakes on ebay are badly drilled. Go for it drill press would be even better. Use a washer if its too big on one side grind it down on the bench grinder to make sure the bolt does not trash up the intake any worse.
Wait the intake is 87 or later? Usally they have slots in them already.
Old 11-07-2012, 01:11 PM
The issue will be getting the underside of the bolt heads to sit tight on the manifold. A little grinding on the manifold should solve this problem.
Bogie
High Rise V/s Dual Plane adantessr Hotrodding Basics 8 07-12-2010 10:43 PM
Intake swap: dual plane airgap to single plane ? y2k600f4 Engine 6 09-19-2009 05:11 AM
Intake Manifolds Dual plane Vs Single Plane chevy_power427 Engine 20 08-05-2008 04:00 AM
Single vs Dual Plane for High Perf Street Motor leejoy Engine 11 11-12-2007 10:02 AM
Turning manifold from dual plane to single plane sb72elcamino350 Hotrodding Basics 3 03-27-2004 09:24 PM
