Originally Posted by cobalt327
Total Seal has conventional as well as gapless first and gapless second ring sets. You might want to expand (no pun intended) on what Total Seal rings you're recommending to the OP.
either Gapless set has worked for me. Some people claim a gapless second cannot work because it holds pressure between the top and second ring but I have a Cutlass outside that shows different. The Gapless second set is a little cheaper, but like I said the pro's recommend Gapless top.
I believe those rings are all ductile iron as well, but it's been a while so I would check on that before you hold it to be gospel.
