cast iron powerglide - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2005, 09:36 PM
My 55 cast iron power glide still leaks, it leak's from the selector shaft even though i have a new seal in it. Has anyone herd of a metal clad seal to replace the rubber seal? It seam's to be leaking at the housing, not the shaft Also i believe the previous owner put in another dipstick witch might be different than the origional stick, does anyone know how to calabrate the oil levil, becuse it chatter's and slip's a little in reverse untill the engine rpm's are raised. With the oil at the full mark my reverse line presure is low and the gauge flicker's like it's sucking air. If i put 1.5 more quart's of dexron it it the presure is higher and it's better in reverse, but i don't wanna over fill it. c-ya sling.
Old 05-24-2005, 04:42 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Take your dipstick to a boneyard and compare it with the correct one, if it's different then purchase the correct one or mark you existing correctly.
You say "it seems to be leaking at the housing" which says to me that your not sure. As with any leak that your not certain you know where it is coming from you should pressure wash it clean and then run it a bit. This will help you identify for sure where the leak is.
Old 05-24-2005, 05:50 PM
Dear lonestar, when i say it's leaking at the housing. I shoud of said it's leaking around where the seal fit's into the case not around the selector shaft. as far as the dipstick goes, i have a 58 glide and i'll match it uo and mark it accordingly. c-ya sling
1955 cast iron powerglide slingslingbinks Transmission - Rearend 8 09-11-2008 08:53 PM
Welding Cast Iron OneMoreTime General Rodding Tech 3 01-22-2005 05:46 AM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
Cast iron powerglide slingslingbinks Transmission - Rearend 13 09-30-2004 10:18 PM
Cast Iron Powerglide Trouble StineDogg02 Transmission - Rearend 1 07-09-2003 08:42 PM
