cast iron valve sighns - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2011, 09:51 AM
i pulled off my cast iron heads and put on some eddy heads and noticed a few of the exhaust valves were white looking and some were darker colored? the last time i was running it i had it idling for about 20 minutes while i was bleeding the brakes. what would cause this? if its spark related, would a msd or equivallent box help?
Old 01-29-2011, 09:56 AM
Sounds like too lean air / fuel mixture.
Old 01-29-2011, 10:10 AM
would the the lean mixture be on all the valves? whats another tell tale sign of running lean if you cant inspect the valves?
Old 01-29-2011, 02:21 PM
327NUT's Avatar
The spark plugs, white is too lean, tan is good, black is too rich. Google it, you'll find lots of info on reading plugs.
Old 01-29-2011, 04:31 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You can't get plug readings off idle. Best bet is WOT, immediatly shut off, coast to a stop and pull 'em. Rich or lean at idle and cruise or WOT are two different issues.
Old 01-30-2011, 01:05 AM
4 Jaw Chuck's Avatar
Brand new/rebuilt fuel injection engine exhaust valves are usually very close in color but once they are used and have a few miles on them they turn different colors too, I wouldn't worry about it...you can't tell much about an engine by looking at exhaust valve carbon deposit colors unless its burning oil.
Too many variables.
— Han Solo
cast iron powerglide rhoffler Transmission - Rearend 2 12-21-2010 10:27 PM
Cast Iron Heads El Co 406 Engine 3 08-29-2007 09:50 PM
cast iron powerglide slingslingbinks Transmission - Rearend 2 05-24-2005 06:50 PM
Brake parts cast iron or cast steel brainsboy Suspension - Brakes - Steering 0 05-26-2004 04:42 PM
Welding Cast Iron Centerline General Rodding Tech 10 01-26-2004 02:46 PM
