Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Caster--Camber
Thread: Caster--Camber
Old 07-07-2006, 12:00 AM
1969NovaSS's Avatar
1969NovaSS 1969NovaSS is offline
turbo lag......yeeeeehaaaaaaw
caster is good for straightline stabilty. If you have power steering they usually run more caster then manual. -1 degree camber at a stand will not do anything. If you can ask the guy to see if you can sit in the car while he does an alignment to see how that will affect it. also lift the frone end of the car up with your body to see how it reacts. on my nova I set the alignment at -1 but thats wehn I sit in it and the front end comes up 3/4'' and goes to almost 0. then when i get on it with no sway bar it goes back to -1.5 so its even more stable at high speeds.Just some helpful tips.
