any changes ?
Is the Car stock ? you should be able to find original specs on a mopar resto forum. Is it the tubular axle or an IFS system.? I have had problems with tires wider than stock and a lot of offset in the rims. stock wheels and tires were OK, If you have raked the car, little tires in front, big rears it will change the actual effective castor angle.
