casting # - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2013, 08:42 AM
casting #
I just picked up a engine this weekend but i can't find any info on the block # stamped on the back. # is GM 3370014 anybody have an idea what it's out of???
Old 02-21-2013, 09:33 AM
The number is likely 3970014, its a 68-79 350. Need the suffix code from in front of the pass cyl head to know what it was in originally.
Old 02-21-2013, 09:49 AM
hcompton's Avatar
Old & Furious
camaro block for 69 to 70 also used in some trucks and cars. Good chance its a four bolt main block. I have one in my garage right now that is four bolt from a camaro.
I also think this a good block as far as rebuilding goes i would use it for sure. I find a lot of the 010 blocks are four bolt mains but its all a crap shoot until you pull the pan and check the mains and crank numbers. then you can tell for sure what it came from.
casting# yardman Hotrodding Basics 3 09-28-2011 09:13 AM
which casting do you think is better calhoun Engine 3 04-13-2008 01:14 AM
can someone tell me what these casting # are denny1977 Engine 3 01-22-2006 12:01 AM
Casting # sscamaro_510 Engine 8 02-01-2005 08:31 AM
Does anybody know GM casting #'s? Sub_Urban_454 General Rodding Tech 6 10-20-2003 04:54 PM
