casting 3964290 will they fit a gen v 454? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2012, 06:44 PM
Hey guys I need some help...someone just offered me these pair of heads yes. casting 3964290 for $100..if I end up buying these heads I am definitely going to get them cleaned up..I did some research and found out these heads are from the early 70's, closed chambers on the ls-5 engines...I have a gen v with the peanut ports..I decided that I want to reach 500hp..I have the peanut ports and heard the power on these heads are restricted to 400-450 hp...would these heads fit my block? If so, would you recommend these heads?? Any input is.very much appreciated
Old 06-25-2012, 07:01 PM
F-BIRD'88's Avatar
Yada Yada Yada
There is a special head gasket that allows using the old gen IV "Mark IV" cylinder heads on a Gen V block. I do not know the part number.
The issue is coolant hole mismatch.
Old 06-25-2012, 07:42 PM
Oh okay...what are the pros and cons of the mark iv?? And will I be having issues with the heads being closed chamber?
Old 06-26-2012, 10:46 AM
V305's Avatar
On the Border
I believe it was Victor Reinz Brand, I think I saw a carcraft article using those gaskets
Old 06-26-2012, 03:37 PM
DoubleVision's Avatar
Mark IV heads on Gen V 454 block
Old 06-26-2012, 04:14 PM
Yeah Ive heard about the victor reinz gaskets as well as the fel pro gaskets..if I were to purchase these gaskets...would it seal the heads for good without any leaks? Or would I have to make a few mods? I've been doing a ton of research regarding this topic but I still haven't gotten a straight up answer whether or not its a good idea..some say yes they've been successful and others say that its a bad idea..any engine expert out there can you share with us your knowledge on this topic? Is it a good idea to put these heads on a gen v or am I asking for serious problems? Thx for your input
gen v 454 fatchance2 Engine 8 06-26-2011 01:02 PM
Is there a 12 bolt posi rear end that would fit a second gen camaro? YoungGun77 Transmission - Rearend 1 04-22-2011 07:50 PM
Gen VI 454 MHenricks Engine 2 09-01-2009 08:11 PM
gen 5 454 BBCMudbogger Engine 3 09-09-2008 01:08 PM
will a 4th gen camaro rear end fit 3rd gen? 84Z Transmission - Rearend 2 05-13-2004 07:51 PM
