Casting # - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2005, 05:08 PM
sscamaro_510's Avatar
Casting #
I was wondering if somebody can decode this block casting # for me... The engine is Made in Mexico
#10066036
Old 01-22-2005, 05:13 PM
batman09's Avatar
CLICK ON MY AVATAR
10066036...350...........2 or 4...Target Master/Goodwrench crate motor, 2-piece rear main seal, "Hecho en Mexico" www.mortec.com
Old 01-22-2005, 05:15 PM
lt1bbody's Avatar
Last journal entry: The '85 Monte Carlo
here is what I found at www.mortec.com
10066036 = 350 cid 2 or 4 bolt main. Target Master/Goodwrench crate motor, 2-piece rear seal, "Hecho en Mexico"
Hope this helps.
Old 01-22-2005, 05:16 PM
yea i found the same thing. All this time I was thinking my El Co had a 307 in it and it really had a 350. That's good news for me. How can I find out what this motor was rated at?
Now I can plan a performance build up.
Old 01-22-2005, 05:25 PM
batman09's Avatar
CLICK ON MY AVATAR
here you go...
350 Cubic inches 4.00" Bore, 3.47" stroke
8.0:1 compression ratio.
250 HP @4300 rpm 350 ft. lbs of torque @ 3600 rpm
( These Numbers obtained with a Quadrajet Carb,1 5/8" headers , and an Edelbrock Performer intake part # 2101)
Engine consists of the following parts:
Block -part # 10066034, casting # 10066036 2 piece rear main seal 4 bolt main
Crankshaft- part # 3932444 Nodular Iron 1985 and older flywheel bolt pattern.
Connecting rods- Part # 10108688 Powdered Metal
Pistons- part#12514101 Cast Aluminum
Oil Pump- part # 12555284 G.M. High Volume Pump
Camshaft- Part#3863151 Hydralic Flat tappet
Intake Lift-.383" Exhaust Lift-.401"
Intake Duration @ .050"- 194 Exhaust Duration @.050"- 202
Lobe Seperation-112
This cam Has a mechanical Fuel Pump Lobe. This is a low end Torque oriented camshaft.
Cylinder Heads- part # 14034808 casting #33417369
1.94" Intake valve , 1.50" Exhaust Valve 76cc Combustion Chamber
7 Bolt style Exhaust Flange Standard 85' and prior intake manifold bolt pattern.
Perimeter bolt style Valve Covers. This head is very similar to the old #882 castings from the 1970's
DeleteReplyForwardSpamMove...
Old 01-22-2005, 06:53 PM
Thanks for the help.
Old 01-23-2005, 06:51 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
el diablo
You can build a decent motor out of the block but throw the heads away.
Old 02-01-2005, 01:45 AM
Would you guys do a heads/cam package on this motor to get my goal of 300 plus HP? or would you just rebuild the whole motor? If so what heads do you guys suggest?
Thanks.
Old 02-01-2005, 08:31 AM
batman09's Avatar
CLICK ON MY AVATAR
It depends on how many miles you have on it.if you have over 25k rebuild the whole thing.Go with a comp xe268 cam and dart 180/64cc-72cc iron eagle heads.You'll be over 300hp.good luck bm
