which casting do you think is better - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2008, 10:19 PM
i have a couple of head sets and i want to know witch would be a better set to build up i would like a good high compression for drag race only hear are the #s
1. 333882
2. 3884520
3. 3932441
rember im on a budget build i know vortex are better but im using whats at the shop just for fun
Old 04-11-2008, 05:34 PM
882's will flow the best but do not like to get hot and if that is a concern go with the 441
Old 04-11-2008, 09:59 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Most 882's are cracked or will crack shortly or are on a running engine- cracked. I you MUST use GM castings, use the 441's. (or 041's)
Just an FYI, you can probably get into a pair of NEW World Sportsman castings for roughly the same money as totally re-furbing GM stuff. Not to mention the power increase.
Old 04-13-2008, 02:14 AM
gonna just buy some dart iron eagle heads that will do it just right
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
Cylinder head casting number Forsaken502 Engine 5 02-23-2004 08:09 PM
74 heads on a 87 block?? punk1c5040 Engine 22 02-17-2004 10:16 PM
Can't Find Casting Date on 12-bolt PrimaDude Transmission - Rearend 0 03-11-2003 08:25 PM
