-   -   Is this casting # known to be a good block (http://www.hotrodders.com/forum/casting-known-good-block-115282.html)
85CHEVY 05-03-2007 05:17 PM
Hi everyone, I have almost got my engine done; should be running by Monday. Just wondering if this casting number (10066036 Hecho en Mexico) is known to be a good block. It is a 4-bolt main block.
chiss 05-03-2007 05:37 PM
according to my paper work that is an 86 Targetmaster crate engine
2pc rear seal, If its got the 993 head castings, thats a decent little
SB. It came in 2 an 4 bolt.
steveyb4342 05-03-2007 06:11 PM
This is what I found
"10066036...350...........2 or 4...Target Master/Goodwrench crate motor, 2-piece rear
seal, "Hecho en Mexico""
2 or 4 is the different mains.
Steve
junior stocker 05-03-2007 06:14 PM
I had one of those. Had less than 20k miles on it, but was 8 yrs old, when it dropped #8 exhaust valve. Still have the block and crank. Those blocks must be awfully "soft" as there was quite a ridge for the miles it had on it. Still going to use it again one day.
85CHEVY 05-03-2007 09:47 PM
Vortec heads are going on it. So it is not one of the higher nickel content blocks?
Arcuden 05-04-2007 02:03 AM
If the engine is not yet installed in the vehicle, check behind the timing cover or on the rear of the block behind the flywheel for "010" (1% added tin) or "020" (2% added nickel), or both. The numbers are big and easily noticed.
There's another thread going on here somewhere debating the benefit of having a harder block (extra nickel).
85CHEVY 05-04-2007 07:58 AM
Thanks, I'll check that out.
