Is this casting # known to be a good block - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2007, 05:17 PM
85CHEVY's Avatar
Hi everyone, I have almost got my engine done; should be running by Monday. Just wondering if this casting number (10066036 Hecho en Mexico) is known to be a good block. It is a 4-bolt main block.
Old 05-03-2007, 05:37 PM
chiss's Avatar
according to my paper work that is an 86 Targetmaster crate engine
2pc rear seal, If its got the 993 head castings, thats a decent little
SB. It came in 2 an 4 bolt.
Old 05-03-2007, 06:11 PM
On the learning curve.
This is what I found
"10066036...350...........2 or 4...Target Master/Goodwrench crate motor, 2-piece rear
seal, "Hecho en Mexico""
2 or 4 is the different mains.
Steve
Old 05-03-2007, 06:14 PM
junior stocker's Avatar
I had one of those. Had less than 20k miles on it, but was 8 yrs old, when it dropped #8 exhaust valve. Still have the block and crank. Those blocks must be awfully "soft" as there was quite a ridge for the miles it had on it. Still going to use it again one day.
Old 05-03-2007, 09:47 PM
85CHEVY's Avatar
Vortec heads are going on it. So it is not one of the higher nickel content blocks?
Old 05-04-2007, 02:03 AM
Perfectionist Procrastinator
Last journal entry: Moving along
If the engine is not yet installed in the vehicle, check behind the timing cover or on the rear of the block behind the flywheel for "010" (1% added tin) or "020" (2% added nickel), or both. The numbers are big and easily noticed.
There's another thread going on here somewhere debating the benefit of having a harder block (extra nickel).
Old 05-04-2007, 07:58 AM
85CHEVY's Avatar
Thanks, I'll check that out.
350 Chevy block casting question flyin99 Engine 7 08-14-2006 08:55 PM
where to get a good 383 long block canter Engine 3 09-21-2005 10:53 AM
Block Casting Identification bluesman123 Engine 2 05-04-2004 08:55 AM
