try 38------- or 39-------
yea I know, but there is nothing there its just a blank space only 6 numbers. On the other side it reads k54 which I looked up and it means it was made in ontario for the k and may 4th.
Besides, if it's a 4 bolt main I would assume it's a 3970010 and go for it. S**T happens. GM is no exception to the rule of "murphy's law".
they have a book at auto that would help you to find it . if you go there look where the repair books are they have a book by the name of how to build a 350 . i look at it today i pick up a 350 4 b man for $150 cast number 38970014
I don't believe it. They do have a 3970014. but I don't see a 38970014 anywhere.
gonna drop the pan here in a bit and I might have got two 4bolt mains for $40, but I checked the heads and they are the 624 castings not so great, but I will practice porting or something on them.
I`ve seen this on many blocks where one casting number is missing. Also seen them where the casting number was so poorly casted you can`t read it. One case I seen one that was miscasted, it had a 400 casting number but it turned out it was a 267. As long as I have the last 3 numbers I`m fine. But since there were many that used 4 inch bores, I check the crank numbers so I can find out what stroke crank I`m dealing with.
dropped the pan and its two bolt mains, cant seem to get the crank to turn over so I put some pb blaster down the cylinders and give it some time. What do I need to do if the motor is seized as far as rebuilding it.
so what is your advice on getting this motor apart, the crank will not move and a lot of water came out when I drained the oil not coolant but water. I assume there it's some rust around thee pistons and in the bore. Shot some pb blaster and wd 40 down the plug holes. Is this crank and rods safe to use given the condition I described assuming it can be turned or polished. Thanks love this site good info and knowledgeable people.
| casting number? | Chevrolet420 | Engine | 5 | 03-25-2009 05:40 PM |
| need casting number help | sam83k10 | Engine | 8 | 07-21-2007 06:49 AM |
| I've got a casting number but.... | JJ350 | Engine | 8 | 03-05-2007 07:41 PM |
| bbf casting number help. | Jared | Engine | 2 | 11-06-2003 11:46 AM |
| SBC casting number | Maverick | Engine | 1 | 12-10-2002 06:38 AM |
