casting number 3970010 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2007, 12:14 PM
i have found the cast number on the block and looked it up but the number corresponds with the 302, 327, and the 350 but i don't know how to find the ci for the block. So can anyone please tell me where to look at on the block or any other way that i can determine the ci.
Thanks
Old 07-18-2007, 12:38 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Use the pad stamped numbers with the letter codes to tell HP size, CI, application & years
Edit, the pad with # is on the block front face right where the head fits to block. Passenger side.
Old 07-18-2007, 12:41 PM
re: casting number 3970010
You'd have to get the casting number off the crankshaft. That'll narrow it down for you. If you don't have a crank, put in whichever one you want. Strokes would be 3"-302, 3.25"-327, 3.48"-350; they're all 4" bores.
Old 07-18-2007, 12:49 PM
The motor is still in the car.
sorry i forgot to share that information.
Old 07-18-2007, 01:04 PM
327NUT's Avatar
Ok then what year is the car? If its the original engine then it won't be too hard to figure this out will it??
Old 07-18-2007, 01:56 PM
It's not the original motor the car is a 1967 camaro.
can someone please tell me more about the pad stamped numbers?
Are these numbers on the block or on the head?
67 camaro
Old 07-18-2007, 02:27 PM
DoubleVision's Avatar
The suffix code is on the passengers side head deck on the block. It`ll be on a pad right in front of the head.
Old 07-18-2007, 02:45 PM
re: 3970010
Can you post the id letters and numbers that you see on the engine block on the the small extension of the block surface just below and ahead of the head on the passenger side. I have some books that might reveal some info re: the year of the engine. BTW my own 383 stroker has a number that I cannot seem to find anywhere yet. V0424ABT. I only know that the V stands for Flint Engine Manufacturing department of GM. Maybe someone could figure out what the ABT stands for.............thx ed
Old 07-18-2007, 09:11 PM
You may have to remove the alternator to get to the numbers on the front passenger side of the block. My bet is that you have a 350, as this was more commonly casted "010" than the rest.
Old 07-19-2007, 06:12 AM
Thanks that worked i was able to find the number and verify that it is a 350 and the year is 1973. my number is VO605TJZ
tenfords
I looked up your number but there is not any number that corresponds with your ABT. the only thing i can tell you is your motor was on the assembly line on April 24 but cant get the year or the ci size until you get the correct suffix numbers. Maybe it is a ABF, or something i don't know. As you all ready now the V is the plan code and the O605 is the assembly date and the TJZ is the suffix code.
can some on tell me how to determine weather the moter is a 4 bolt or a 2 bolt. is this something that i can determine with the moter still in the car?
Thanks
67 camaro
Old 07-19-2007, 06:32 AM
I did a search and there are others that also have the ABT code that are positively 350`s. Only there is no information on what vehicles these engines came in. But there are still many a small block out there that have suffix codes yet to be decoded.
Old 07-19-2007, 06:55 AM
MI2600's Avatar
Member# 3287
Use this for the # sites:
Old 07-28-2007, 01:02 AM
Yes it is a 4 bolt. Every suffix code that starts with T is a 4 bolt truck motor.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
Engine block casting number benharteis Introduce Yourself 3 02-16-2006 07:06 PM
Casting Number Question.... mebeslo Engine 4 10-05-2004 09:07 PM
Cylinder head casting number Forsaken502 Engine 5 02-23-2004 07:09 PM
