casting numbers ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2003, 06:11 AM
New Member
casting numbers ???
hello everyone, i am a bit confuse about what type of engine is this,,, casting #3970010 with V0625F2 at the pad below the altenator..... i have read many threads and even went to the mortec page and that casting # came for different blocks
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
I cant find anything on the serial at the pad either since all i read it says it should end up on 2 or 3 letters for the engine year and make and as u can all see it ends up on F2, and that is clear no mistake about those codes i got they were really clear to read.
the engine is on a 69 caprice with a 327 decals all over it and the owners says is the original but that it was rebuilt at one time... however i was looking at the damper and it looks like a 350 damper, is the damper on the 327 the sames as the one on the 350s?? the engine is on the car so im not able to clearly see the date casting at the flange.... is there any other way i can tell what engine and howmany main bolts is without taking out the engine?? tns in advance.....
Old 06-30-2003, 06:26 AM
banned
N/m you already checked that.
Dampers are usually the same on all sbcs
Old 06-30-2003, 06:35 AM
banned
Possible canidates, make sure that 2 is a 2
Does it have a powerglide tranny? Is it possibly a Z not a 2 ?
yr code CI Tran HP BBL Vehical
1969 FA 327 manual trans. 235 2 full size
1969 FB 327 Powerglide 235 2 full size
1969 FC 327 tur hydro trans. 235 2 B F
1969 FG 327 police/full size
1969 FH 327 tur hydro trans. 235 2 B F
1969 FJ 327 m/t 210 2 B F Vette
1969 FK 327 Powerglide 210 2 full size
1969 FL 327 tur 350 210 2 full size
1969 FY 327 m/t, taxi - - full size
1969 FZ 327 Powerglide, taxi - full size
Old 06-30-2003, 07:01 AM
MI2600's Avatar
Member# 3287
The dampers are, for the most part, interchangeable as long as they match the timing tab.
Old 07-01-2003, 05:11 AM
New Member
im pretty sure is a 2 not a Z however, lets say it was a Z, was that a 2 main bolt or 4???... tnx in advance....
Old 07-01-2003, 06:11 AM
awsum34's Avatar
The last three on the of the group of numbers should be letters. off the head. behind the alternator
