casting numbers for 327 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2004, 02:16 PM
fordguyfordman's Avatar
New Member
I'm still searching for info but haven't found it yet. A friend has just gotten a hold of a 327 and want's to find out some info about it.head #'s are 8776484. cam is 3837137.piston #'s are 3796494. So far we have found out it's a small journal 327 from 63-65. carter afb 4 barrel.Any help is appreciated. thank you in advance.
Tom
Old 11-27-2004, 02:52 PM
Are you sure your head numbers are correct? I have 3774684 but not the 3's you have posted. What I posted came from a 62-64 327 with 75cc chambers. The rest I cannot help you with, sorry
Old 11-27-2004, 02:54 PM
DoubleVision's Avatar
There is no small block chevy head with the casting numbers you listed, all the heads from the 60`s started with a 3, but a 3 is easily mistaken for a 8, also I can`t find any record of a 484 casting. look closer at the numbers, you may need to spray some cleaner on them and do some scraping to see them better. To tell you further of this block, look on the passengers side of the blocks deck, on there should be the suffix code, it should look something like this: DRD as a example. post the suffix code and we can tell you what it came out of and it`s power rating. If you`ll look on the back of the bell housing, you`ll also find the date casting, it`ll look something like this example: A 4 5
A = January 4 = 4th 5 = 1965.
The months start with a letter, A is january, B is febuary and so on.
Old 11-29-2004, 05:07 PM
New Member
you are correct syclone. I asked and it was confimed it's a 3 not an 8
