casting numbers say L.a built camero meaning ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2006, 11:17 PM
i ran the # on my csb it said 70-73 350 then it said l.a built camero whats this mean is it a special block??
Old 01-21-2006, 11:21 PM
larryblack's Avatar
Certified Lead Foot
Not really a rare find. It means it was done at the GM plant in the Los Angeles area and destined to be installed in a Camero.
If the numbers are still legable on the pass front pad, CTB and CTR ended blocks used in Z-28's.
Old 04-20-2006, 01:36 PM
Casting numbers say LA built Camaro
The Camaro/Firebird GM assembly plant is located just outside Van Nyes, Ca.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Chevy Rear End Casting Numbers problem 55 Transmission - Rearend 1 12-22-2005 12:07 AM
350 small block casting numbers 49international Engine 3 09-26-2002 03:54 PM
Casting numbers on marine heads CrazyT Engine 1 09-18-2002 10:11 AM
casting numbers 47fordhotrod Engine 0 05-28-2002 01:30 PM
