CAT 3116 strange problem losing power - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2008, 09:11 PM
Hi there,
I have a 3116D and have a strange problem. I recently had the injectors, fuel pump and turbo replaced and since doing this the boat doesn't run properly. When you run the ignition all sounds well, you accelerate and all is well - the problem is that when the turbo has come in if you lower the throttle slightly and then reapply the throttle there is a huge loss of power for around 3 seconds and then all is well again. You can recreate the problem over and over and it seems to get worse the more you do it. It is as if there is no fuel getting to the engine but there seems to be no obvious leak/disruption. Could changing the turbo, injectors and pump have caused this or could it just be coinsidence. Any help greatly received!
Old 03-31-2008, 09:28 PM
327NUT's Avatar
Howdy...probably the wrong forum, go to www.thehulltruth.com, these are a bunch of offshore boat fishermen that do nothing but talk about outboards and diesel boat engines. Good luck!
Old 12-31-2011, 01:22 AM
hello; your problem can come of wrong settings of injector timing, injector syncro ; fuel settings; FRC - fuel ratio control or turbocharger vaccumvalve not working properly
have a nice day
3116 cat motor josh1015 Engine 7 08-29-2008 05:47 AM
Strange Starter Problem 56xpresso Engine 2 02-20-2008 04:16 PM
Strange idle problem – part warm engine 78transam Engine 2 10-26-2007 05:16 PM
chevy 350 jimang22 Engine 4 07-14-2007 03:49 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
