*Cat. Converter (BIG)Problems!! - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: If you had to choose a way to fix a cat. convertor, how would you do it?
Gut/Hollow out 4 30.77%
buy new one 7 53.85%
leave it be 0 0%
replace it with just a straight pipe 1 7.69%
cut it off and say the heck with it 2 15.38%
Multiple Choice Poll. Voters: 13. You may not vote on this poll
Old 04-20-2006, 10:14 PM
CrazyRoyExhaustfreak's Avatar
I've got A.D.D., want some?
Need Help
Gut it /hllow it out
buy new over $150
rip it off and replace w/pipe
1992 GMC 1/2 ton 4x4 350
will not even go past 65 mph even if pedal is slamed to the floor , Slugish up hills, smells like rotten eggs (BAD).
the exhaust on this truck has iron manifolds, CAT, 3 ft pipe, and nothing else.........rest of exhaust kinda fell off while doing 55 mph down the freeway(opps). It wasn't any good, it was an old rusty flowmaster 1 chamber and the whole piping looked kinda like if it was pieced together by a blind man.
Old 04-20-2006, 10:45 PM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
I would never tell you to break the law by tampering with a CAT. EPA kinda frowns on it, ya know what I mean. However..
if you do not have state regulated safety inspections ..........
Al
Old 04-20-2006, 10:51 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Since I live in Canada where it is not a problem to remove cats go ahead and remove it before it falls off going down the freeway and kills someone. If it does it won't be oops anymore.
Old 04-20-2006, 11:01 PM
Race The Truck
Last journal entry: Son's Truck
I'm all for keeping the smog levels down. so a performance cat would be the way to go.
I kinda like breathing fresher air. You only get one pair of lungs.
Craig
Old 04-21-2006, 07:34 AM
Wiki Edits: 31
cat converters have no restrictions actully, buying a hi flow cat, is just in a larger diamater that is supposto flow better, but dosn't really.
Old 04-21-2006, 09:17 AM
USA1's Avatar
Summit has universal cats starting at $53.00. Weld or clamp it on and be done with it. Catco brand name.
Old 04-21-2006, 04:48 PM
Kevin45's Avatar
Just one of the guys
The universal cat is one way to go. On my '93 Silverado, I had the cat removed because the muffler guy screwed it up (long story) but I replaced it with a Thrush muffler (Cherry Bomb knockoff) and ran my pipes off of it. The muffler is a straight thru. The truck sounds good but not too loud.
Kevin
Old 04-21-2006, 05:10 PM
poncho62's Avatar
Wiki Edits: 5
Try moving to Ontario....they are super strict here about such things.
Ontario Rodders
Old 04-22-2006, 12:05 AM
The brick in mine turned sideways, so I busted it up with a tire tool & put it in a ziplock bag. But mine had a good pair of mufflers behind it, so nobody noticed, except for all the horses that got turned loose.
Old 04-22-2006, 05:30 PM
bigolblackie's Avatar
I wouldnt say they are super strict about it. Nobody has looked under my truck to see if I have them or not. I have twin magnaflow cats,and they were only $60 each. I passed the emission test without the air smog pump on.In Ontario,as long as you can pass the emmision test,then your good to go. I recomend buying a new universal cat.
Old 04-25-2006, 02:23 PM
cruiser22's Avatar
Shadetree wannabe
I would say take it off. either gut it or pipe it. I had one replaced 3 months ago and its going bad. It was a new one that was lying around mechanics shop. have a feeling it was to small for my truck. I dont know about the full size trucks. but with a s-10 if you take it out completely the o2 sensor goes nuts. have to have a simulator or somethinganotherdoohickey.
Old 04-25-2006, 11:04 PM
'96 and up with OBD-II has an O2 sensor downstream from the cat, and it will throw a code if the cat isn't working. Earlier cars generally don't know the difference.
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 12:42 PM
TPS sensor and Converter question. Parisienne66 Engine 5 05-12-2005 10:50 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-26-2004 11:32 PM
Torque Converter Application BMRIde85 Transmission - Rearend 4 06-17-2004 02:57 PM
possible bad toque converter? Deadtemple Transmission - Rearend 9 10-11-2003 06:53 PM
